I’m breaking down and installing a rear camera. I”m thinking of running the wire from the license plate, behind the tail light, and then into the cab. But I don’t know how to get the wire into the cab. I need to tie into the reverse light anyway to trigger the camera.
I could run the wire underneath and then into the engine compartment and through the firewall. But that seems like it would be a little less direct.
Is there access from behind the driver’s tail light into the cab? If not, should I drill a hole for access?
