Have a noise that I can’t seem to find a lot of help on. Have a few clicks in the trans/clutch when engaging/disengaging clutch. Sounds like it’s at the front of the trans instead of pedal. Jeep still shifts perfect and drives fine. But there’s also a noise when clutch is disengaged. Not bearing noise but more of a loose flywheel bolt noise or something of the sort. Almost like a small piece of metal bouncing around if that makes any sense. I took videos but not sure how to add them. I’ll try to figure that out. Any thoughts?
