I’ll have my dad sit under the hood to read it as I go 40mph down the road
I’ll have my dad sit under the hood to read it as I go 40mph down the road![]()
Hence GoPro, or a Glow Shift or whatever electronic gauge.
I'm becoming more and more fond of wanting to check my fuel pressure at a glance.
And since I started playing with oil pressure and temperature I'm equally curious about fuel temp.
TJs have regulators in the pump. I'd like to build a custom fuel pump assembly with no regulator and an in and out hose fitting...the fuel rail would have a regulator on it and a return line. This can and will significantly drop fuel temperature.
You may want to hang a Schrader valve on that 1/8" port and get a test gauge with a 3' to 4' hose you can route out the hood and tape where you can see it.
Or again an electronic gauge.
I did mine this way (for now) so I could glance at the fuel rail and confirm pressure. This was largely in response to putting the cheapest Brute Power fuel pump in my 97.
Did you get it figured out? My 2006 2.4 just started doing this same thing, hoping maybe
it could be the same problem and this could provide some insight.
After assuming the worst on mine, it turned out to be the coil pack. Thanks goodness for fairly cheap and super easy.
