I have already started sanding and wire brushing the frame, suspension, and the underside of the tub.
I’m not sure what paint to use on the tub.
I’m planning to use Krylon Rust Tough Enamel Paint for the frame and suspension but the tub itself has rusted areas. Will that paint suffice or I will need to get Krylons primer Rust Enough version since there is still paint on the tub?
What do you guys recommend using for painting underneath of the tub?
