So i’m not sure what the issue is but I did a full brake overhaul tried to bleed the lines, when i finally finished, with their car on the brakes feel super spongy and the pedal almost has a sponge sound to it, my brand new rotors and pads brake very… Okay, no improvements and if not probably worse than before, so then I try to re bleed the front brakes with my father, left side was good it flushed a few bubbles then got a constant flow, however the front right side when i try to flush, I get a quick good stream coming out, then some bubbles and then it’s just air with nothing coming out we tried to pump and flush about 17 times and it’s always the same thing so now i’m not sure what the issue could be since there’s no leak on the lines I see and it’s not happening to the left side.
