That’s some serious corrosion.![]()
God I hate my phone … if you only knew how much auto correcting I need to correct to each post … even a properly spelled word can be changed to another word completely, without a typo … ugh.
They use the same part numbers as Hayden they carry both.
These are the wind speed numbers I got on the meter lmk what you think. I had the meter against the grill meter shows 97f as the temperature of ambient air those numbers were also pretty consistent across the whole grill from 5-6 mph this was after heat soaking the system and ac full blast idling for 30mins ect at 215f
I was taking my readings from behind the fan on my truck. Checking at the grill might be better and it's certainly safer.
My reading from the grill might not be proper to compare to since I have two coolers in front of the condenser. But I'll check from the grill and then near the thermostat housing and send you what I find.
Yes I have a hex style for access but brass … the sensors I was referring to were water temperature sensors and various others that plug into water jackets in both aluminum and cast iron. If I can get 50-75 years in a brass sensor (and VSV valves) in a water jacket, then I’m not worried in the least about my TJ. I’ll take the ease of removal over any galvanic concerns. There is also a galvanic potential table you should look at, I believe brass on aluminum will corrode the aluminum and brass on cast iron will corrode the brass. You don’t see brass freeze plugs failing routinely, do you?
I have enough inout from the stock gauge, I know the gauge isn’t accurate and I know they apply a bell curve to make it stay near “normal” but I been looking at these gauges for 18 years, I know what’s warming up, normal, warmer than normal, I can characterize when the thermostat is full open. Also, AC performance is affected by things such as fan performance (clutch and blades) as well as radiator heat saturation, a cooler radiator helps the AC get I bit cooler.
So the Robert Shaw conflict comes from the fact that we have Chinese knockoffs … I have a small stockpile of real American made Robert Shaw stats, all tested and put on my shelf. My chevys and TJs all use the same ones, so it makes sense to keep them on hand.
If your a science guy and clearly have the digital readout, I’d like to see you upgrade to a Robert Shaw, take measurements of peak temperature as well as characteristics of how fast your jeep somes up to temp, how steady the coolant temps are controlled, etc. I’ll even order you a stat for this data. Then as a final experiment, repeat with a high flow thermostat housing.
Again, I don’t think your Mopar was working, as far as I know, I never had a defective Hayden, typically the failure mode for these things are that they loosen up, not overtighten…
And I don’t say much more than “my jeep is at a safe temperature” l, I realize our dumb downed gauge readings, but they are consistent. Like I said, take the numbers out of the equation, perhaps keep 210 but label it 210-ish … you can see when you have a thermostat stuck open, takes forever to warm up, and runs cold (I bought a Jeep once without a thermostat). I can tell brand of thermostat by the needle. I bought another Jeep with a French thermostat and the needle behaved uniquely. So to say it can only confirm proper temperature is false, but the truth isn’t far off.
Sounds good to me let’s keep this scientific as possible guys I get that many of your jeeps cool fine but bring actual data to compare not just (my gauge say so) plug in a scanner read the actual temps tell us what your jeeps cooling system is don’t lie to try to make your look better that helps nobody but your ego I’m trying to build a reference for all Tj owners.
Ok 1 hour of idling a heat soaked system now here is what I have 224 on the digital gauge 97f outside temp on the meter and 6.3 mph reading on grill opening
Would you mind comparing to CFM? I don't have MPH as an option on my device.
Correction: I have mph...I'll log both.
Measure from top of grill slots also all my data is at a 720-750 rpm idleWould you mind comparing to CFM? I don't have MPH as an option on my
So what do you do when the 8mm square becomes round? Asking for a friend.
Update:
Taking MPH and CFM, but I'm taking engine bay's reading in front of the pressure sensor on the AC line since there's not enough room for the device at the thermostat housing.
I have a steering cooler in that area, so I measured from in front of my finned cooler.
Note: I went back and measured from the top where you measured from and the numbers were the exact same compared to the numbers I pulled from lower in the grill.
Keep in mind that we are using different devices, I have two coolers in the grill, and it's 105* and sunny where I am.
I'm using a Mopar fan and Hayden 2791 fan clutch.
Engine cold: 4.88 mph / 4569 CFM (grill)
Engine cold: 4.88 mph / 4994 CFM (engine bay)
195* Idle: 4.53 mph / 3913-4241 CFM (grill)
195* Idle: 4.53 mph / 3913-4241 CFM (engine bay)
210* Idle w/ AC: 4.53 mph / 3913 CFM (grill)
210* Idle w/ AC: 4.83 mph / 3913 CFM (engine bay)
The weather app says it's 105* outside, but the Jeep says otherwise.
Before AC
After AC
What’s your idle rpm?
This is about what I see as well with the OEM fan. In hotter conditions the temp creeps up to 230 at idle. Highway temps are 205-210 depending on speed.
You know there ARE computers that are a lot easier to deal with. Just sayin'. You don't have to deal with the nuisance of a PHOOOOOONNE!!
Yea, THIS is a problem. You can try cramming a 3/8 extension in there. Put some penetrating oil in there like PB Blaster, or my favorite “Mouse Milk”.
