Need some help.
I had the P0303 code and low compression in cyl 3 and 4. Rebuilt the top end and the misfire code went to P0304.
Checking compression all is good. 135, 125, 135, 125 cyl 1-4.
Replaced plugs, wires, rotor, cap, coil and still the same.
Read it could be the #4 injector heating up so we put an insulator in it - no change.
Replaced all the injectors. Ran better but same code.
Read it could be the O2 sensor. Replaced with aftermarket and got O2 errors. Replaced with NgT part and we are back to P0304 code.
Tested for vacuum leak by spaying brake clean to see if any increase in rpm. Nothing.
