Replaced control arms on the Tj with Clayton arms, finally got rid of that useless drop pitman arm. Changed out both front and rear trac bars. Clayton arms fit well, previous owner must have had a stretchy tape measure because nothing was square. All set now!
Finally got my spot light switch installed and the seat heater switches wired up ready for the new seats to go in.
When I get new axles, the lower 4 spots will be front locker, rear locker, air compressor, and something else.
Love your setup!
Do you know where I can get the switches for the heated seats? I couldn't find them the last time I looked.
Edit: Found them :)
Love your setup!
Edit: Found them :)
Here is where I got the switch.
https://www.ebay.com/itm/2664361086...pid=5337789113&customid=&toolid=10001&mkevt=1
I just used the rocker from that switch on an OEM fog light switch so the back lighting worked. You'll need the OEM switch and the wiring pig tail to replicate what I did fully. If you don't care about the back lights working, you can just get the switch above.
Those are the ones :) Just bought three so I'll have a spare.
I'm currently running PRP switches at the bottom of the dash bezel. I plan to replace my two on/off rocker switches, previously used for cameras, with these when I move to a double din bezel.
I've got 8 either used OEM or new switches. 4 are for future use and 4 are spares. I've torn a switch apart and don't see where there is much of a failure point in them, but I'll keep the spares. I've also swapped out both lights in all my switches, including the ones installed, with LED back lights and the on light.
I'm still waiting on my PRP seats. That's what my switches are going to be heating. How are the heaters in them?
Reactions: MikeE024
I really like the looks of these for OEM look. May go with them and just keep the seat heaters I have to install as on/off, even though they have high/low settings. In all other vehicles I have with seat heaters that have 2-3 settings, I always just run on high anyway...
Reactions: mjonesjr84
Same, I like the OEM look. IF the XJ center console would fit in the TJ, I'd put the factory seat heater switches in that console. The only reason that my Silverado ever gets on the lower settings is because it does it automatically. My PRP seats will have just on/off so I'm not concerned.
They work well enough, but they aren't burners like OEM setups.
I don't notice them right away, but they come in handy when I'm out on cold nights with half doors and no windows.
My biggest issue is forgetting to turn them on until I'm cold and almost done driving. :D
The only complaint I have in my Silverado is that they automatically turn down and then off after a period of time. It pisses me off since I use them as back pain relief as well.
Reactions: Kiwi TJ
That post got me thinking-
I’ve got 2 sets , $69 , same product, Chinese made-both installed the same -
In my TJR they are on par with any car-
In my LJR they get hot hot, as in these have to be turned down.
In my LJ mR they get hot hot, as in these have to be turned down.
Are they aftermarket or from PRP?
Aftermarket, Amazon -
One member told me most are made by one company.
Have had a sciatic nerve type issue recently- will go just sit in the LJR and crank ‘em up.
My chiro says ice is better for inflammation. Heat sure feels fine.
