Broken OBDII connector
CJDalling
Lifetime Supporting Member
Muscle Shoals, AL
Hey y'all, long time reader, first time poster. On one of our many off road trips, I guess I sent it a little too hard. I broke my OBD port with my foot or leg. I was going to buy another one off of Rock Auto. But I need the wiring diagram so I can re-pin it correctly. I have an 05 X, manual. Can anyone help me?
I just did mine
Get wire labels or tape and label each wire before you take out the pins.
I used a very small jewelers screwdriver to de-pin the connector. Search on you tube if you are unfamiliar with the process.
Be cognizant of how the pins are oriented in the housing when you remove them so you can make sure they are installed correctly into the new housing.(top vs bottom of pin) this will ensure they lock properly.
On my 97 the positive power wire in the bottom corner corroded out. I ordered a whole new connector and pigtail on Amazon...then de pinned the wire I needed and spliced it in to my existing port.
Still like to identify the type of connector pin. Would have been easier to cut the wire back 1/2" and crimp in a new pin.
