LED headlights
JeepMama
North Carolina
Our Jeep came to us with the Bluetooth LED headlights. The QR code on the control module takes me to an app that is entirely in Chinese and does not work. The only English I can get from is "ble". Any idea how to get connected to them without buying a new controller?
Cut your losses and buy new LED or halogen h4 conversion.
This ^^^
My TJ had a set of rock lights (more like accent lights because they really weren't bright enough for more than ricer looks). Same setup. Launches an app that was useless. All things as they were, I pulled them out and replaced them with some proper LEDs.
Lots of choices for LED headlights. I have tried a bunch and settled on the Holley Retro Bright LEDs. Modern LED technology with a retro, period correct look.
Just put these in today. $67 on Amazon. MGLLIGHT 7” headlight. I have not hooked up the halo DRLs or amber turn signals yet. I might run the DRLs to a rocker switch so I can turn them off.
sounds like an “extra” feature thats not necessary
Im assuming the headlights work with the dash control, but the APP likely just gives you control of multi-color DRL outer rim lighting
I wouldnt waste my time, just use the headlights as is
Reactions: MikekiM
Same ones I bought
I also didnt bother wiring up the DRL yet
I think they can blink yellow with the turn signals
With NO REGARD TO COST, what is the highest-power headlight set with the most extensive illumination available???
Do you want a bright light, or an effective light?
You can get cheap LED lights that are crazy bright, but with no good cutoff and you will just be blinding oncoming traffic. Good lights also have good pattern.
Hi all, I'm looking to buy these trucklites and was wondering what the "MP" in the part number means(if anything)?
These should still work with a TJ correct?
Hi all, I'm looking to buy these trucklites and was wondering what the "MP" in the part number means(if anything)? These should still work with a TJ correct?
I see you're up north, do those lights have heaters for snow and ice?
Don't know about the part number.
Personally, not a fan of LED headlights.
YRMV
Reactions: James9100
I love my Jeep factory JK LED headlights conversion. It does not look obnoxious like some of Amazon stuff and should last much longer.
YRMV
No heaters to my knowledge. I ended up passing as it was only one light and not a pair as I thought.
