Finally got my new to me seats installed. Pulled transfer case and replaced transmission output seal. While i was under there found the rear brake line is rusted out so have that on order now.
Reactions: Kiwi TJ
Trouble shooting cluster lights not working I’ve tried everything.
But also prepping for my new Currie Dana 44 rear axle housing with 4.88 gears, Detroit truetrac LSD, chromoly axle shafts, and I got a rebuild kit for my front Dana 30 with 4.88 gears and a whole new 1 ton steering set up, new radiator aswell so I’m going to be busy over the next month
Busted out my 03 today to get it ready for the warmer months, seems to be getting low power and backfiring occasionally at higher speeds.
Weird intake “wheeze” when it’s warming up that seems to go away.
vacuum leak? Bad fuel pump? Not sure:(
Manifold gasket leak?
Reactions: Duner
