Roll-n-jack hard top lift with an LJ
Satchel_Boy
Mineola, TX
Howdy, first time posting here. I saw a pretty good deal on a roll n jack through Facebook and was wondering if anyone has given them a shot with an Lj. I know they have adapters for a regular tj but I was wondering if it’s worth risking the money to give it a shot with the longer top.
It’s a jack system for a hardtop, think it was a big kickstarter thing a while back.
Reactions: P man
I have had my LJ top off many times. I remove it by myself. The majority of the weight is in the rear. A JK top without the front panels is about 68" and an LJ top is about 80". I doubt the weight of the extra 12" would cause any issue. The LJ top is significantly heavier, however. Jku aprox. 90lbs vs LJ 199lbs. The company doesn't list a weight capacity but does not recommend lifting tops with additional weight like roof racks. I don't think I would trust it with something as expensive as an LJ top. Roof hoists are cheap and effective if you have the room. If you need something less permanent and movable I use a rolling scaffold that I just slide mine on to.
The rolling scaffold sounds like a good plan, are you able to get it to the height you need pretty exactly, and what lift are you running?
I've used it with a 2.5 suspension and 1" body lift and a 4" suspension and 1 inch body lift combo. It's still a bit awkward but not to bad. I just climb in the rear and brace my back against the top. I just move it a couple inches at a time until the rear is on the scaffold. Then it's easy to slide back. It sits high enough I can still park in the garage.
I’ll definitely look into it, I think the only issue I may run into is the barricade tire carrier I’m running. I’ve also been looking into this method I just need to price out the lumber.
Reactions: 06lj
I rigged up a top lift with a harbor freight 120V, 440 lb. hoist, some cable fittings, unistrut (Superstrut or Adamax) for the lifting frame, a couple spare lengths of 2x10 that was hanging around, and miscellaneous hardware. My top hangs nicely in the garage from March to November. It could probably be replicated for around $200.
I simply open the tailgate, unbolt my hardtop, climb up into the bed, use the guns to lift the hardtop up over my head, turn, and jump out of the bed…
Oh crap, that was 40 years ago. DAMMIT!
(Hardtops was lighter then…🙂)
Exactly what I used to do with my full top on my '83 Scrambler - almost 40 years ago!
How many days off and trips to a chiropractor would that require today? 🤔 I think I’d at least have to sit on the ground and think about life choices for a minute after doing that. :LOL:
Reactions: NashvilleTJ
Very interested in this. I tried lifting my top and its just too damned heavy. Is this the scaffold you are using? I was planning to build a wooden table to slide it on but this saves me time.
That's the one I use. I picked mine at HomeDepot but the Amazon one looks to be identical.
