I'm about to order the Tuffy under front seat drawer that I just found out about and they make it for a tilt and a non tilt seat. They say your build sheet will say "East Access Tip and Slide Seat". Well my build sheet says "Easy Access Pass Tip & Slide Pass Seat" but it doesn't mention one for the driver's seat, however I think I have it. The driver's seat has the little cloth pull tab and when you jerk on it the seat does tilt up and slide forward but not as nearly far as the passenger side, probably because the steering wheel is there. Only a very skinny kid could squeeze past it and into the rear seat. So I'm guessing I need to order the one for the tilt seat unless I'm missing something?
