You might have more space for recovery gear if you clear out the ducks…
Other than my cooler everything is in soft bags. That way they don’t gouge things up or roll around.
With the new teardrop trailer coming next I’ll have to pack my generator but that will stay in camp and not on the trail.
I noticed everything I had in bags did great
I built a platform in the rear of my LJ, it locates the uprights off the seat tracks and is turnbuckles down on all four corners. The height is so a quart of oil will stand up. I have a box for spares, oil, trans fluid,cam crank sensor. Spare hose, belt nuts bolts etc. I have one soft tool bag, one for recovery gear, and one for tire stuff, air up hoses, plug kit, starting fluid. Everything goes under platform.
The vertical panels locate into the seat tracks, then the top goes on between 1” x 2” runners mounted to the top. The front panel with a horizontal support to keep the top from bowing bolts to angle brackets attached to the uprights. The turn buckles attach to the deck brackets with through bolts to tie downs on the top of the deck. I can pull it out in about 10 minutes and put the seat back in if I want.I would love to see a picture of that and you answered my other question and that was fluids
You guys are killing it
Does the smaller
Box slide inside ?
Liking it ...
Is that a special type of lid? I use the same Wolfpacks for offroad storage, and they lie flat like so:
