Review: Auxbeam "Starlight Flow" 7" LED headlights with DRL and Turn Signal Halos
jscherb
Wilmington, DE
Auxbeam just introduced a new set of 7" LED headlights they're calling "Starlight Flow" lights. They say these are rated at 8000 lumens per pair in low beam and 16,000 lumens per pair in high beam, which is quite a bit higher than the Wrangler's factory headlights - an average halogen sealed beam headlight bulb (TJ) or H13 bulb (JK) has up to about 1000 lumens in low beam and 1200 lumens in high beam. The lights have aluminum housings and polycarbonate lenses (the JK Wrangler's factory headlight lenses are polycarbonate). They are DOT and SAE approved.
They sent me a pair just before the holidays to test in advance of their release.
The contents of the box includes two headlights and adapters for H13 plugs - the H13 adapters are for a JK. The plug on the headlight is a standard 3-pin H4 sealed beam plug which will fit a TJ. Also included are wire and suitcase connectors to connect the DRLs and turn signal halos, instructions, a large Auxbeam decal and gloves with rubber grips to help with installation.
An Auxbeam promotional image:
As a first test, I installed one in a TJ grille in the workshop to compare it to the stock sealed beam.
I powered both the LED and the sealed beam and my first impression is that the LED is a lot brighter than the sealed beam but I'll have to get it out on the road to verify that it improves visibility.
The headlight has a standard H4 plug on the back on a short cable sticking out of the headlight which matches the prongs on a sealed beam so the TJ's headlight plug will connect directly to it. The kit also includes a pair of H4-H13 adapters to use these headlights in a JK Wrangler. There are two extra spade connectors on the headlight cable, the white one is to illuminate the DRL (Daytime Running Light) halo function and the yellow one is for the turn signal halo. The DRL halo light is white and the turn signal halo is amber.
Next, using clip leads and a power supply I tested all of the functions of the light.
In this next photo, both headlights are illuminated in low beam. The LED side is deceptive in this view because it's a got a projector-style lens and unlike the sealed beam at right, not much light is wasted out the sides.
And both in high beam:
DRL halo:
Turn signal halo:
In this video I first applied power to the DRL, then the low beam, and finally put power alternately to the turn signal halo. The initial power up of the DRLs results in some animation.
As you can see in the video, when the turn signal is illuminated, the DRL turns off, and when the power is removed from the turn signal, the DRL lights back up.
The tests above were done with clip leads and a benchtop power supply. To install these in the Jeep, Auxbeam has supplied a number of suitcase connectors and wire leads. The suitcase connectors clamp onto an existing wire, penetrating the insulation and completing a circuit to the wire to be tapped into the existing wire.
For the turn signals, a wire from each headlight will need to go to the wire for the turn signals on that side of the Jeep, and the connection to the turn signal wire will be made by crimping the suitcase connector over both the turn signal wire in the Jeep and the turn signal wire from the headlight. Auxbeam has supplied extra wire for that purpose.
The DRL function can be wired in several different ways. If you want to control when the DRLs are on or off, you can connect them to power through a toggle switch and this can be either switched or unswitched depending on whether you want to be able to turn the DRLs on when the Jeep isn't running. If you want the DRLs to be on automatically whenever the Jeep is running, connect them directly to a switched circuit, such as the one that powers the radio.
Next I pulled the grille off the JKU to access the headlights, removed one of the factory housings and plugged the new LED in. I did this to verify that the headlight doesn't have a problem with being in a CAN Bus vehicle because some LED headlights have been known to flicker in CAN Bus vehicles. These work fine - just constant steady light. Some LEDs, such as the H13 LEDs bulbs I currently have in the JKU, come with a CAN Bus driver to eliminate flicker but these must have built-in circuitry to eliminate the possibility of flicker.
I didn't do a demo video in the JK because Auxbeam did one:
They also did an instruction video showing how to to the installation including details on how to wire the halo functions in a JK:
Since the housings and plugs are a direct swap for 7" sealed beams, these lights should work in most vehicles that have sealed beam headlights so I decided for the nighttime road test I would install one of the new LEDs in my '06 Wrangler pickup to compare the left and right sides on the road. I installed the new LED on the driver's side for the nighttime test:
With the lights aimed at the garage door I took these next photos to compare the lights in daylight. The left photo is low beam, the right is high and on both photos the left headlight is the new LED and the right headlight is the factory sealed beam. The LED is much brighter.
The instructions that come with the headlights explain how to wire both the DRL and turn signal functions for the JK/JKU but they don't cover wiring in the TJ so I did some experimenting. It turns out that the halo turn signals are compatible with the TJ's floating ground front turn signal wiring as long as there is power to the DRL halos. Operation of the turn signals is shown in this next video... I did a close up to show the wiring - notice a pin sticking in the white wire/green trace in the front fender marker light/turn signal plug - for this demo that "pin tap" is connected to the yellow wire on the headlight with a clip lead, and the white wire on the headlight (DRL) is connected directly to the battery with a clip lead. You can see that the DRL and turn signal functions work fine with the headlights on or off.
So to wire the turn signal function in a TJ, connect the yellow lead of each headlight to the turn signal wire for that side front fender, and connect the white lead (DRL) to a switched power source (the radio fuse in the fuse panel is probably a good choice) so the DRLs are lit whenever the Jeep is running. In my '06, the correct wire for the left turn signal is white with a light green trace and on the right it's white with a tan trace but different year TJs will have different colors for these wires.
After dark I did a quick drive around town to see how the extra brightness translated into extra visibility. These lights offer a significant improvement in nighttime visibility. The beams seem well-focused on the road, and no oncoming drivers flashed their lights at me to indicate that the lights were bothering them - the vertical cutoff of the beam is very well defined and below other driver's eyes. The new LED is only on the driver's side, the stock sealed beam is on the passenger side so things would be even brighter with these LEDs installed in both sides. This is low beam:
The lights are definitely more powerful than the factory halogen sealed beams, and the pattern is much more defined.bbbb
If you're not a fan of the DRL or turn signal halos, these lights may still be worth considering - the improvement in nighttime visibility from the projector headlights is excellent and you don't have to connect the halo functions if you don't want to use them.
The lights are now on the Auxbeam web site: https://auxbeam.com/products/7-inch-135w-dot-approved-led-headlights-with-drl-turn-signal
Since the theme of my pickup is "retro" - I designed the truck to be what the factory would have done if they were to build a modern version of the classic Willys pickup so the tech look of these lights isn't right my truck but I'm sure lots of Wrangler people will go for this look. I'll put these lights aside until I find an appropriate home for them.
Do they have a non-halo version (I don't think so). What about a heating element to keep the lenses clear of snow? They keep reaching out to me to do reviews and install videos but I just don't know enough about them.
Seems like a great price for a quality light but I'm in the same boat; the aesthetics would be completely out of place on my TJ. I have trucklite knockoffs which I'd eventually like to replace for a better pattern, but trucklite is about the most modern look I want as it's transparent lens and reflector design is believably period-correct for domestic vehicles circa 2006...projectors are out of the question.
Reactions: hosejockey61
DRL halo:
Turn signal halo:
always appreciate/value the time you take on the evaluations!
I agree - for someone who wants the halo look, I believe these are an excellent value and they're definitely a significant improvement over stock halogens.
They do have quite a few projector options, but they're all higher-power replacements for vehicles that came from the factory with projectors. They don't have a non-halo projector sealed-beam replacement headlight at this time. These headlights do not have a heating element.
Thank you. I try to share as much info as possible so people can understand the details of any product I review.
The product for my next review arrived today - this 100ah lithium battery. I'll start a thread on it in a few days after I do some initial testing.
Reactions: BlueC
Do not heat above 70C (158F) is probably an issue in an engine compartment. Is this intended as a secondary or camping battery where it could go in the back?
There are a few questions I'm waiting for answers from the company, using the battery in the engine compartment as a starting battery is one of them.
I plan to use the battery as an auxiliary to run my refrigerator and other overland/camping accessories and it will be carried back by the kitchen so it won't be subjected to extreme heat. I currently carry a deep cycle lead/acid back there that the lithium battery will replace for a comparison test. The lithium battery will also be used as an alternate starting battery though, the way my dual battery system is designed the auxiliary battery can be used as the starting battery with the flip of a switch on the dash.
I'll review the battery in detail and provide details on my dual battery/overland power system and solar charging in the review thread.
Reactions: freedom_in_4low
Over the past few years I've tested a number of LED headlights for Auxbeam, and for over a year now I've been running Auxbeam H13 LED bulbs in my JKU and they're a great improvement in visibility. I ran them all last winter without a snow buildup problem and we haven't had any snow to speak of so far this year, but I'm waiting for the snowstorm that the LEDs won't be able to deal with due to snow buildup.
The other day the windshield washers in my JKU stopped working and the reason turned out to be that one of the hose connectors broke - apparently a victim of engine compartment heat. The only connector I had on hand was a tee, so I put that in and plugged the third leg:
And that gave me an idea - what if I ran a hose from that leg of the tee to washers installed on the grille? Every time I wash the windshield, the headlights would get sprayed with washer fluid that won't freeze in the winter. The washer pump has plenty of pressure to supply both the windshield and the headlights. For the summer, the hose could be disconnected from the tee and the tee plugged again.
Might be worth trying. Images of a washer nozzle held in place on a TJ grille...
Maybe not an ideal solution, but very easy and inexpensive to implement. And it it works well but washing the windshield and the headlights at the same time isn't desired, an extra pump could be added to the washer reservoir to just feed the headlight nozzles, and coincidentally a few minutes ago I got a marketing email from MPJA, one of my favorite surplus electronic components suppliers, and this submersible pump is on sale:
https://www.mpja.com/01-04-24.asp?r=292539&s=3
Drop the submersible pump in the washer reservoir, control it with an Auxbeam switch panel, and install nozzles on the grille and run a hose from the submersible pump to the nozzles.
[URL]https://www.mpja.com/01-04-24.asp?r=292539&s=3[/URL]
my LJ came with a hardtop, and therefore already has a second pump, but I no longer have the hard top. So I could use all the existing controls and circuitry and just re-plumb it to spray the headlights instead...once I figure out the nozzle.
