got my cooling system thermocured and new Zerex GO5 put in today, completing my 100k miles fluid refresh ! atleast now I know at 100k miles all fluids except the blinker fluid have been changed , just haven't found the damn reservoir for it yet but I'll keep looking :ROFLMAO: :ROFLMAO: :ROFLMAO:
I finally figured out how to change the blinker fluid in my TJ. Changing this fluid is a must, if you put in LED lights to stop them from blinking too fast. The fluid was actually sealed in when they molded the rear lights. So, I had to drill a small hole in the bottom of the rear lights, and a small hole in the top to let in air. Then, all the old fluid drained out. It was kind of yellow and my blinkers didn't shine as bright as when my jeep was new. I then, plugged the bottom hole with a tiny rubber stopper with ribs on it to keep it from falling out. I ordered Mopar Blinker Fluid and carefully refilled it. I added another small rubber stopper to the top hole to keep dust and water from getting in. I had to do both rear lights. Presto. Blinker fluid changed, and I'll do a write with pictures for everyone. Cheers. Merry Xmas.
I like the Maximum Strength Blinker Fluid. Amazon has it:
https://www.amazon.com/dp/B06ZXSKDZG/?tag=wranglerorg-20
After nearly two months I went to pick up my jeep from my work parking lot. The battery was pretty low but thankfully it was in the 50’s here today so it was able to crank albeit slowly. Got her running and let the cobwebs burn off and then was able to make it across town shifting and steering with my good arm. I had forgotten how much I loved driving it even though it rides like a jeep lol Merry Christmas to me, I’m glad to have my TJ back home.
Good to see you vertical, brother. You have certainly had a year.
Merry Christmas to you and the famiky, and here’s to a better 2024.
Jeff
Jeff
Thanks Jeff. It’s been a rough couple months for sure but I’m on the other side of it now thankfully. I appreciate your thoughts buddy and hope you have a Merry Christmas
Fred
[URL]https://www.amazon.com/dp/B06ZXSKDZG/?tag=wranglerorg-20[/URL]
Modding is a slippery slope.
Must add item are cross drilled brake lines...
