Hey all. Could use a little help here. This morning, on the way to work, the rear propeller shaft decided it no longer wanted to associated with the rear differential and the transfer case. I heard a loud bang and lost my gears. I was able to coast to the shoulder and investigate. Turns out that the “rear propeller shaft” was completely missing. My apologies if this is not the correct term. It is the shaft between the transfer case and rear differential (as I mentioned above). So, I put the beast into 4WD and was able to use it as a front wheel drive vehicle for the final trek of my journey to work…successfully.
So I have the Jeep parked in a safe location where I can leave overnight for however long I need to. Also have other vehicle options for driving. Time is not necessarily of the essence, but obviously want to get it back on the road.
Question 1: is it safe to drive the jeep in 4WD back and forth for a few days, or would this cause too much wear and tear, and possibly damage other components?
Question 2: is this a diy job or something that would have to be done professionally? It appears to be a bolt-on component. The differential side looks easy enough to replace at the u-joint, but I’m not as confident on the transfer case side. Can someone point me in the right direction as far as parts needed and a run down of the process of replacing it?
Question 3: it looks like the shaft completely snapped at the plate (removable plate?) on the transfer case. Is this going to be an issue or is this part of what would come with a new shaft?
Thanks everybody. I’m just trying to brainstorm and plan this out. I’ve replaced/worked on many parts of the Jeep (and vehicles in general), but not this. Thanks for any advice.
