That makes sense. Just makes me wonder if that axle bolt pattern is a standard Dana 60 and shaft thickness is the same. That way if you don't have the wide kit and want to upgrade to 35 spline you can just buy the correct length from anywhere that sells shafts not specifically from teraflex. Good to see someone with actual experience with them too. Being a standard tj I feel the full float kit should give me plenty of strength in the rear to handle 37-40s.I just did the full kits front and rear on my JKUR. I stuck with 32 spline for now since I’m already regeared and still running factory lockers. They make you use the wide kit for the 35spline conversion because it’s parts interchangeability with there Tera 60 axle. You can order the Tera60 housing with a diff and nothing else and the hub conversion parts will all bolt into it I’m fairly certain.
