I replaced the flywheel, clutch, pilot bearing, throwout bearing, master and slave cylinders in my 2001 Wrangler. Replacement seemed to go fine. I had no difficulties. The cylinders came assembled as an all in one unit and supposedly doesn’t require bleeding.
Pedal feels fine- firm but not hard, but the clutch clearly doesn’t disengage. Grinds and won’t allow into reverse nor any other gear. Running with trans in neutral there are no word noises or smells. I’ve read that the hydraulic clutches aren’t adjustable.
I’m at a loss where to go from here. Any suggestions for a newbie on this site? B Many thanks
