As much as I like my York, I wouldn't bother installing another one again.
Why? I use my OBA regularly, probably more than my actual air compressor sitting on the work bench.
What would you do instead?
No idea. I haven't had to figure that out. But I do know that there are plenty of good options that cost less than a York and are sufficiently quick.
I just curious why JJvw wouldn't do it again. Your write up on the install was great by the way.
This is what that Sight Glass looks like once installed.
What is the adapter and how full do you fill it? What oil do you use?
I shared a link in the previous page, but here it is again.
Oil Sight Glass, 1/2 NPT Hex Head Domed Oil Sight Glass, Brass Bulls Eye Sight Glass Liquid Level Gauge Oil Indicator Window for Air Compressor Gearbox Tank https://www.amazon.com/dp/B09DPPJGCJ/?tag=wranglerorg-20
I just make sure there is oil visible at all times. I stop adding oil once I see it halfway.
Just any 10W 40 motor oil. I add some STP oil treatment for some zinc and recommendation from the ORO guys.
I used the Amazon link and ordered the sight glass, but it looks like there’s an adapter fitting as well, correct?
Ah. Yeah, sorry. You may be able to find it at a hardware store. My local Home Depot didn't have it. You can get it here. Some Yorks may have a different fitting, so make sure this is what you need.
TAISHER 5PCS Brass Pipe Fitting, Reducer Adapter, 3/8-Inch Male Pipe x 1/2-Inch Female Pipe https://www.amazon.com/dp/B08N657TR3/?tag=wranglerorg-20
Thanks! The sight glass it comes with has been practically useless.
Did the sight glass come with the kit? I’ve got a York system the PO put in, but checking the oil is a bit of work. I’d like to see if I can get the sight glass separately maybe if the port is in the right place.
