Still having death wobble issues
Cooper Smith
Amherst, Ohio
Hey guys. Still having death wobble issues. There’s no play in any components. I have replaced the track bar, hubs, and rotors (spacers were seized to hubs). Walmart did my new tires and balancing in august, don’t flame me lol, and I had an alignment done at a tire shop. It still had a little bit of a shuffle when you hit bumps a certain way, but now it has come back. I have taken my spacers off (2 in spring lift) and now are on stock wheels. The stock wheels get death wobble more, but they’re old and have bead weights and are a little corroded. I have an appointment to get new tires (going to 29”) on Sunday. I’m lost and am seriously considering selling the Jeep. Issue after issue is getting old.
It shakes itself apart. I can catch it by slowing down before it gets bad or by coming down about 30 mph. Starts around 55 mph. It is DW, no doubt.
Wait till you get new tires, and insist on a perfect balance. You have a straight axle vehicle. This is not like balancing tires on an independent suspension. The tires are actually fighting each other since they are rotating the same direction (rather than opposite which would favor physics agreement. See precession.
Wait till you get new tires.
Fingers f***ing crossed. I see your edit as well. Will do. I’m thinking that’s what it is. Odd for it to be fine, not so fine, then downright horrible after different wheels. After this it’s going to a 4x4 shop.
Reactions: Rickyd and JMT
Absolutely cannot. Nope. The steering stabilizer, more correctly known as the steering damper, is strictly a passive device and it cannot cause shimmies or DW. It can temporarily mask the symptoms of DW fooling some into thinking it was the cause and cure but that's it.
Does mine sound like a balance thing? Especially it being speed related?
It’s interesting you say it wasn’t very bad but it came back. Have you verified everything is tight since it came back?
It absolutely could be caused by an imperfectly balanced front tire. Especially if one of the rod end joints on the drag link, tie rod, or track bar is worn and loose.
With the tires on the ground have a helper do repetitive quick short left right turns while you closely watch the steering system for sideways slop at the rod ends. Rotational play is normal for the drag link and tie rod but not sideways play.
