No sir 19 so you were close
High-school dropout at that,started working at a young age to help family, but since we're way better im now currently buying jeep parts since I want my jeep to be a rock crawler/daily
Edit- To add if yall don't like how I write go ahead and teach me, as well to add I was tired after work on little sleep so I was just rushing to finish my apparent mindless talk!
You have a few misconceptions that you are allowing to dictate the path of your build that would be better left out of the equation for a bullshit LCG build.
1- uptravel matters, find out why. If you can't build uptravel into the suspension design, then everything is compromised and it does nothing well and most everything poorly.
2- arm angle really doesn't affect ride quality at reasonable lift heights.
3- a wider stance isn't the answer to anything except looks to the detriment of performance.
4- an over the axle trackbar sounds cool and all until you figure out that building the rest of the steering to make it all play nice isn't as much fun as it could be.
5- there is no such thing as 1 ton steering. That is a term used by folks who don't understand shit about steering. 1 ton vehicles have steering under them. That neither makes the components used good or desirable to copy.
6- air bumps are for suckers who read the internet written by other folks who want to spread the misery around. They are not fun to install, they are not cheap, and they are beyond annoying in actual use. They are a secondary suspension component used for higher performance race applications, leave them there.
7- the only thing that stops a normal rig at normal lift heights from being a good daily driver is tire size. Keep it no larger than 35's and it will be just fine.
And finally #8- if you to build a belly dragger with big tires and fucked up steering because that look appeals to you, then knock yourself out. Just stop with the bullshit justifications that are based mostly in fallacy to do so. To be very clear, I have no issue with how you want to build your rig. I have big problems with the lies you are telling about why it should be that way and I do realize you likely came by them honestly.
