First off, love this forum! This is my first post but I've been reading and lurking since buying a 2000 TJ Sahara a couple years ago. The forum has been an invaluable resource. This issue aside I love the hell out of my TJ. And even with this ride quality I can't dream of driving anything else.
Issue: When I bought the Jeep, every crack, bump, pebble or seam in the street and on the highway could be felt. I've tried to improve this by following forum advice but still have the same experience. I've researched the hell out of tires and shocks both here and on other forums. I'm out of ideas and thinking that maybe load range C tires are the issue, although this forum led me to think they were a good buy. Potholes send a concerning jolt through the cabin which sounds like the thing is about to rattle apart. It rides like it has no shock absorption in the suspension whatsoever. However, I've run through seriously everything except replacing the tires with something else. I live near the Cascades, so my goal is to have a mostly stock daily drivable Jeep that still has good 4x4 capability on forest roads on the weekends and camping trips. Specs below.
As purchased:
Lift: 0" (stock)
Shocks when purchased: KYB Excel
Tires when purchased: Toyo Open Country 265/75/r16, almost bald, think they were load range E
Things I've tried based on my research here:
Lift: 0" (trying to stay close to stock!)
New coils: Old coils caused Jeep to swing/overhang forward on steep hills, especially when braking, replaced with new Moog OEM spec coils, stability restored!
Factory spare was still mounted, Michelin LTX 225/70/r16, so tried going back to the same size
Switched bald Toyos to BFG KO2s 225/70/r16 load range C @ 28psi - HARSH
Changed shocks to Rancho RS5000x - WORSE ride than before
Changed shocks to OEM standard duty from Crown - no improvement, still HARSH
Current state: BFG KO2s 225/70/r16 load range C @ 28psi, Crown OEM standard duty shocks, no lift. Yes I've tried airing them down to 24psi. Maybe makes the tiniest difference, def not enough to warrant driving on a tire that is clearly, visibly under-inflated and takes your foot to the floor to move it.
Are these tires really that stiff? Curious to get everyone's take. Maybe the BFGs and Ranchos are better in a larger size and lifted TJ? I can't imagine this is normal considering how much people gush about KO2s and RS5000x here. But maybe I should try a set of Michelins. Just feel like I've got to be missing something here!
As purchased:
Lift: 0" (stock)
