I don't see it as a problem, I have to source oil with zinc for my TR6 and it is also a straight six tractor motor they use in them...something to do with the flat tappet design of the engine.
Great video! This will be my next task. I just bought a 2006 TJ. I'm going to do front and rear diff's. The video used rtv. Is lube locker gasket a better alternative?Good stuff thank you. Factory service manual might be of use[emoji12] but I have all of you fine people! Good video. Definitely helpful thank you
If the gasket was done right it wouldn’t leak. I certainly wouldn’t try it without have gear oil and rtv on hand.Anyone know if its ok to unbolt the lowest 5 bolts on the diff cover to install a diff skid plate, then reinstall the bolts? or is that sort of thing not advised and will mess up your gasket/seal potentially?
I know the bolts are best tightened in a special order so thats the only reason I ask...just curious if anyone has any thoughts on this.
It’s sbsolutely fine. Nothing will leak. Just be careful not to strip them out when reinstalling. They are prone to strip. I think it’s 20ft/lbs, but just hand tight with a normal wrench. No giving it the gusto. Yes, I have installed a Warn differential skidAnyone know if its ok to unbolt the lowest 5 bolts on the diff cover to install a diff skid plate, then reinstall the bolts? or is that sort of thing not advised and will mess up your gasket/seal potentially?
This is what I used. My factory build sheet says I have a Trac-Lok Differential in the rear. The service manual says to use it but I dont think it says how much. The bottle gave a ratio to shoot for so I ended up using 2 oz of the 4 oz bottle.
https://www.amazon.com/gp/product/B000TTEX8W/?tag=wranglerorg-20
