I went with SeatbeltsPlus.
The belts are nice and they click into the original latches, but honestly I'm unimpressed.
I learned that they are actually made/sold by
Seatbeltsolutions.com & the insert in the packaging advises that installation instructions are available at THEIR website.
Looking at the product offering for the
97-06 front Wrangler suggests that the lap belt portion is connected to the spool (like the original belts), but what I received is NOT what is pictured.
The belts that I received have
3 anchor points, not 2 and their installation instructions are
100% INACCURATE. (and WTF is a "TROX" socket, anyway?)
They say to use the original 2 bolts, but if the lap belt anchor plate is attached using the same bolt as the spool, it tilts the spool making it unusable.
Unless you attach the lap belt anchor plate using a different anchor point, these belts
DO NOT WORK.
I opted to mount the lap belt tab to the forward bolt on the roll bar plate (right next to the seatbelt spool).
The other thing that I noticed immediately is that they do not extend smoothly.
You have to CAREFULLY extend the belt or it repeatedly locks up as you try to pull out enough to latch it.
Definitely NOT worth the price.
