LS - Rabbit Hole
Hemi - Sunshine and Rainbows!
Why do I not believe that
LS - Rabbit Hole
I know fuel mileage isn't your primary concern with the newfound power but is it better than the 4.0l?
Did you end up using the LS1 exhaust manifolds paired with your Novak engine mounts?
Depending on the tune too. I’m sure there is a fine line where you can get food reliable power and fuel economy in there too.
IIRC, the cast iron LS weighs about the same as the 4.0L, combine that fact with the added power, and the power to weight ratio of the LS swap in a TJ, and it HAS to get better fuel economy than a 4.0L.
Given the "morning hot laps" and burnouts I'm saying no![]()
Yep! And I'm still getting the tune right, but I'm getting like 3mpg more than the 4.0L and having way more fun.
Nice! 17-19mpgs is what ive heard before for these swaps.the 5.3 is a great motor. Not like the 6.0l i put in my 70 k20. It gets 10-15.
Its an lm7 right? Stock cam and heads? I'm guessing the premium fuel is to help play it safe and let you get more agressive with timing?
Are you using HP Tuners? I have a LS swap going on a C10 and will eventually need to tune it. I haven't researched this stuff for a while. I've done some stand alone GM TBI stuff in the past.
Just as a FYI, when you start adding timing, it will effect you AFR. Not a lot, but enough to have to revisit it. Generally more timing will want more fuel. Which is a good thing because that all means more power!
Is this thread still kicking? I've done a 6.0 LS2 swap in my 05 LJ making it a ton of fun but still ironing out some details. Specifically the Jeep PCM is finicky only running the AC sometimes and never the cruise control. I bought a reprogrammed PCM from Wranglerfix which works fine in his TJ but not well in mine. Any other sources for reprogramming the Jeep PCM?
Mine is insanely fast. I can pull on my son when he’s driving my Ram with a 400hp+ Hemi. I have 4.10 gears and 33’s tho.
Did you ever modify your tune? Or did you go straight stock? I watched all your videos multiple times over before I began my swap and I think you stuck to stock everything. A tune can definitely help with your throttle response.
HPTuners just released an update to read/write JTEC ECMs…so you could turn off the diagnostic codes that are popping up that cause the CEL. I still haven’t done it on mine because the software is still in beta and that kinda freaks me out.
is it shifting at too low of an rpm?Good to know. Novak did modify my ECM but I really have no idea what they did to it so maybe the answer is at least I should try the tune.
