I like how neat and professional your trailer wiring looks. Andy
Needed to tuck it away from departure angle as well as I could.
I need some with dropping the skid plate. This is an 00 Wrangler with an auto transmission.
I've removed the 4 nuts that are holding the transmission to the skid plate. I thought that was enough to disconnect the trans from the skid plate. I am using a floor jack to lift up the bell housing of the transmission. I am expecting the trans to separate a bit from the skid plate, but they seem firmly attached still.
Is there anything else that I need to disconnect so that the auto trans and the skid plate are no longer attached?
Now you need to lower the skid plate to access the transmission … the easiest way I’ve found is to take 5 of the skid bolts out of the skid plate but leave one in and rotate the skid out of the way… be sure and keep your jack under your bell housing…
While I have the skid plate off, is there anything else I should be doing maintenance or inspection wise besides changing the transfer case fluid and changing the AT fluid?
The old AT oil pan cork gasket seems to be absolutely adhered to the housing. Any tips on how to break the seal so that I can remove the old AT pan? I've tried a screw driver and a small pry bar and neither is working, but I haven't really pushed that hard either. And yes, all the bolts have been removed except for 2 that are very loose to prevent the pan from suddenly dropping.
Try something with a thin wider blade such as a paint scraper, hit it with a rubber mallet.
Of course! That's how that works!that worked. thanks!
and of course, the corner that broke open first was not under the catch basin.
1. If I leave the bottom of the transmission exposed without the oil pan attached for about 1-2 days, will that be OK?
2. Any tips on how to get the cork gasket off the old oil trans pan? I am getting a new, deep pan, but I want to keep the old one around just in case.
if it were me, and it was gonna be a couple of days, I’d probably put it back up with a couple of bolts, mainly to keep it from dripping all over the driveway and the best way I’ve found to get the gaskets off it with a razor blade and dont nick the surface…
My garage floor is epoxied so I don't have to worry too much about dripping and staining the concrete.
Check the condition of the rubber transmission mount. Inspect the frame where the skid plate attaches, remove any rust/scale and repaint. Good time to install a t case shifter cable if you still have the original z gate shift mechanism that was OEM. Coat the skid plate bolt threads with antisieze before you reinstall. Consider placing a thin washer on those same bolts, between the skid plate and frame, to leave a tiny gap there to flush out crud that likes to live between them.
