Hooked up the Thinkdiag2 to my 2005.
I’m not sure what to make of the following info.
So because this called the entire thing into question for me, I wanted to compare it to a known-good reader.
My micropod2 and my $35 eBay windows 7 laptop arrived late this week I got that set up this morning.
Thinkdiag2:
So the values match. (I ran the DRB3 with engine off so 5.0 is the last stored value, and the thinkdiag2 was wobbling between 4.9 and 5).
So the only issue is that the thinkdiag2 isn't programmed to correctly interpret negatives. I might submit a bug report and maybe they'll fix that in a future version.
Thanks to this thread, I picked up a thinkdiag and was able to do a PCM relearn and the P0016 I've been fighting with for years seems to be gone. I don't know why that worked when it seemed like nothing else would and I was smacking my head on a metaphorical wall.
I don't have a screenshot from the thinkdiag but I did see that it's set at 65XX.X , but it does say in sync (can't recall the exact numbers, but before the PCM relearn the learned position was 12, and after the learned position is the 65XX.X) my question, since I have been driving it lately, if I wanted to dial things in closer to the positive side of 0, would I need to go thru the whole process of finding tdc again and then wiggling the opda until i am closer to 0, or could I just loosen and wiggle since it already was set close to TDC, and confirmed by my shop, a couple years back.
6553.5 would be -0.1, 6553.4 would be -0.2, 6552.5 would be -1, and so on. I'm not sure there's any downside to the difference being negative, but it would definitely be easier to keep it positive so you're not having to convert it in your head in real time. If you have it synced as close as you can to 6553.5 and you're DTC is gone, I would leave it be.
Okay, I'll get the exact values when I'm home from work, I can say that after the relearn the value didn't shift while driving and I've taken it out on the road at varying speeds and rpms ranging from neighborhood to highway driving, and for the first time since 2018 was able to put more than 5 miles on it without the DTC coming back. Fingers crossed it'll stay, because aside from taking the jeep out to get groceries up the road i haven't been able to take it out and about for a long time. If the DTC stays gone for a while I'll finally feel comfortable doing the other various repairs I wanted to do, but that was my big head scratcher until I found this thread and decided to try it out
Edit: I also wanted to address that it did still say the "at start" was out of sync but everything else read "in sync" after relearn
To avoid the value from being negative, I set the difference to 0.6-0.7 degrees (the difference bounced between those values).
I made it a point to stay above 0.5 but less than 0.8 simply because doing so worked for others.
No need to find TDC. Just loosen the clamp down to the OPDA, rotate it to your desired number, then clamp it back down making sure that your difference number is still dialed in when the OPDA is tight.
I then did the manual relearn after dialing in the difference to match the relearn number to the difference number.
Edit: words
my apartment gets a bit frustrated if people work on cars at the complex, even for stuff that doesn't involve fluids lol
6553.5 would be -0.1, 6553.4 would be -0.2, 6552.5 would be -1, and so on. I'm not sure there's any downside to the difference being negative, but it would definitely be easier to keep it positive so you're not having to convert it in your head in real time. If you have it synced as close as you can to 6553.5 and your DTC is gone, I would leave it be.
Could the Cam Crank values be shown in the Mode $06 data on OBD2? I see around 15 values, but they're all integers. Maybe the scan tools scale them somehow?
Paging all thinkdiag2 owners from this thread:
@richard-jefferson, a new member here, has posted in this thread that he's trying to get a working cam position sensor for his 2003 TJ, and like the rest of us, he's discovering that the OEM sensor is no longer available. I told him that some members have had luck using the thinkdiag2 on their NGC-equipped (2005-2006) TJs, and that it might also work for his JTEC+ PCM. Has anyone been able to connect to a JTEC+ (1999-2004) PCM with a thinkdiag2? We're trying to find out if it can perform the SET SYNC procedure (see my first post in this thread). In the absence of that procedure, perhaps there's a data channel available like the NGC's CAM CRANK DIFFERENCE that could be monitored while rotating the OPDA to sync the cam and crank position sensors. I have neither a thinkdiag2 nor a JTEC+ TJ, so I'm "flying blind" here. Can you help?
Edited to add the graphic of the JTEC+'s SET SYNC procedure from Post #1, for convenience:
Definitely could be. All the values come through in binary, so if they're 16 bit their decimal equivalents will be 0-65535 and it's up to the tool to correctly interpret that into a number that makes sense to humans.
I looked into this a bit last year but never was about to find the definitions for the mode 6 values.
I was hoping one of the non-Jeep tools let the TIDs slip somehow.
Looks like I may be ordering a Thinkdiag. I don't thing the 2 is necessary, right? The difference is only $20 right now, so the 2 may be worth it for future-proofing? Do you need the subscription to read the values and/or set it to relearn? I'm wondering how useful it will be in a year.
Would the Mini display the values? I don't mind doing a reset to relearn.
