I'm trying to find the cause of a chirp/squeak that I'm getting.
What I'm experiencing
In 2wd, accelerating from a dead stop I hear a chirp/squeak up until about 10-15mph then it goes away, kind of after the initial load is off the engine.
In 4wd, it does not chirp/squeak when accelerating from a dead stop.
When going over rough pavement at speed, it chirps/squeaks until I am over the rough spot in 2wd or 4wd.
Trails are just annoying as hell, it’s constant.
It appearsto be coming from the front
Cannot make it chirp/squeak by manually cycling the suspension
What I've tested/done/replaced/upgraded since I’ve owned it, and the chirp/squeak is still there
I've tightened, tugged, pulled, pushed, and shook just about everything under the Jeep that I can get my hands on.
Replaced all control arms
Replaced front and rear track bar
Replaced front and rear sway bar links
Replaced rear sway bar bushings
Replaced front rotors, pads, and calipers
Replaced all shocks
Replaced front drive shaft
Replaced broken transmission mount
Replaced hood catches
Checked muffler mounts
Checked front brake dust shields
Replaced front axle u-joints
Replaced front hub assemblies
Pulled rear drive shaft and drove with just front drive shaft
Pulled front drive shaft and drove with just rear drive shaft
Lubricated hood hinges
Greased hook latch assembly
Wrapped hood latch hook in electrical tape
Greased skid plate bolts
Shut off engine as speed, hit bump, still squeaked/chirped
There are no poly bushings
Lubricated transfer case linkage
Lubricated front sway bar bushings
Checked radiator supports
Here is a link to the chirp/squeak. It's important to note that it is NOT a constant chirp/squeak. After initial acceleration it goes away unless I hit a bump. If I accelerate from a rolling start, it doesn't chirp/squeak unless I hit a bump. The bump can be as small as running over a manhole cover.
Replaced all shocks
