jeepster1407
@Sunny Side Up tough break but it turned into some awesome upgrades! Any interest in selling a pair of those shackle mounts?
This is easily one of my favorite builds and its not just because you're a fellow yellow LJ. Sucks about the lockers but those upgrades are well worth it.
If it's not too personal can I ask what all in you have for the last upgrade? I'm looking at doing the same but possibly with e-lockers. It gets cold here and I worry about cracked air lines and internal leaks.
Robert at RWKHaussupply.com, Id recommend him to anyone. give him a call, he saved me a fair amount off retail. Not to mention he is awesome to work with.
I wrapped up the front stretch project. I used Barnes4WD JK front coil mounts to make the coils centered on the axle tubes. It took some modifications to the brackets to get them where I wanted. The track bar and drag link are the exact same length, the exact same angle, and very very close to being in line with each other. With the improved geometry and the hydro assist, I’m happy with how the Jeep is handling. Well worth the time and effort to redo the track bar.
How much front stretch did you go? Did you relocate the steering box? Thanks!
Any more on those BA shackle mounts?I'm working on some changes to the design then I plan on placing an order for around 25sets. Ill keep the build profile updated when they are available and will likely be posted on Ebay.
Nice build, really like how you did the front stretch. What bump stops are those? Any clearance issues with the antirock? Seems tight between the links there.
What’d you do differently this time? Made it look easy.
It’s gotta be the 2” front stretchjk
got the rear tires more towards the wall on the passenger side, But I say mostly commitment level. Rolled into it smooth and stayed on it with the right amount of wheel speed.
Just say "auto" here in out
Nice job! I "had to" winch out.
Saw this the other day @ 15:30, the girl driving is like 11 or 12 they said prior.
