lawyerspann
Installed my adjustable sway bar disconnects.
Sent from my iPad using Tapatalk
Did you get the correct length disconnects? You should have some adjustment available, plus they are installed incorrectly. The U-Straps should go on top of the sway bar.
Correct length, yes.
Had a friend install them, he is a diesel mechanic BUT not a Jeep suspension specialist obviously! Nor does he read instructions!
Thanks.
When you redo them, make sure the sway bar is horizontal of maybe 1-2 degrees above horizontal max.
Correct me if I am wrong, but I think the instructions say 10 degrees over horizontal, If that is not true, I need to adjust mine too.
Buddies are good like that...Thanks!
I just redid them myself AND called my buddy and thanked him for making me look stupid.
Thanks!
Thanks!
One more question, did you grease them? They look awful clean![]()
CodaMan I didn’t grease them and I bet my buddy didn’t either. I’ll grease them. I have a tube of red grease in the barn.
Thanks.
That is what the instructions say, however, I contacted JKS tech when I set mine up because I had very little adjustment left. When they saw my photos they said that I had them adjusted too long and to set the sway bar closer to horizontal. I then did a little more research that confirmed that closer to horizontal was proper.
Yes. Here's the link. I paid about $225 total ($20 was for standard shipping) and I got it within a few days. It's the whole linkage assembly and motor.I have to do this ASAP! Did you go with a mopar part?
2005 RHD TJ Sport
2010 BMW 528xi
