I put some new rims and tires on the Jeep today
I‘ve been busy since I bought the Jeep including replacing
Spark Plugs
rear diff fluid- looked clean
front diff fluid- looked black
transfer case fluid- looked black
replaced steering shock
replaced radiator and thermostat
installed disconnects
front sway bar bushings
installed B&M magnum grip pro shifter
new exterior door handle paddles
black vinyl wrap to cover up where it looked like a bear tried opening the door
light bars
under seat amp and sub and raised rear seat
new led tail lights
and lots of little things etc etc
brakes pads and rotors have arrived and will be next
Spark Plugs
light bars
new led tail lights
Is that a factory color?
Reactions: John Cooper
in progress today- a Hooke Molle over head "console"- I have a couple ideas to pivot off of this- such as a overhead map light- looking for recommendations 😁- it was not quite bolt in for the 05 TJ. Adding the Auxbeam switch panel- looking tidy up there.
Last couple days I made a couple rod holders, and on the "new" tub I took 3 hours to extract(drill through) a broken bolt and patched a three of the 15 or so holes with sheet metal plugs glued in with automotive panel adhesive( holes from rocker guards and a roof rack)
