So, I'll try to keep this short. Boiled the power steering fluid on a 12 hour drive, ordered a new PSC pump. Got the one for the 4.0 by mistake with the attached reservoir. I'd like to use it instead of swap it out, but the high pressure line doesn't fit, so I'm going to make some.
1. Will PTFE -6 AN line handle the pressure/can it be used for PS applications?
2. -6 feed and -8 return with a cooler sound right? Or go -8 both sides, or...?
3. How important is the idle switch that is inline on the 2.5L, can it be left off or worth adding a tee to keep it?
