What have you 3D printed for your TJ?
I have to get my items sub'd out to a printing service. Right now I'm waiting on a third brake light fixture for five 8mm red high power leds.
If you end up in the south bay area during a typical work day for some reason I can probably print it for you. Limited on PETG colors though. I do have black. I think I have black polycarbonate too.
Are the red dots LEDs or houses for LEDs?
Edit: reread your post. You already have it printing
Unfortunately I don't get over the bay area. Most of the items I've had printed lately have been from ASA, which holds up well to UV.
I could always paint too.
The red LEDs shown are just for representation and not part of the print.
This one has the whole assembly. You can print the sliders separately if you only want them.
[URL]https://www.thingiverse.com/thing:2523126[/URL]
As cool as that is I’m looking for the slider knob on the actual hvac control
Sounds good. Let me know if you ever need anything. I'm semi local.
Same for anyone nearish San Jose/Santa Cruz.
I printed some prototype paddle shifters for my 6 speed auto. Printed in PETG with neodymium magnets in the arms and micro switches in the center. It actually works well. I want to make the paddles a bit larger and change the angles slightly. Eventually I plan on making it out of milled aluminum, carbon fiber sheet and compressed carbon fiber.
I printed a set of speaker pods for my dash 4x6 speakers, they work great.
I do have a question. I want to hide my passenger airbag switch and put a little coin tray or similar in that spot. Any of you printed a tray for that opening? Didn't find one on thingiverse or thangs3d.
I've done something similar. The airbag switch is relocated under the dash and I had a flat panel trim piece printed to replace it. I didn't do a coin tray because I have the Auxbeam switch panel mounted right above where the airbag switch was.
How do I design a new piece? I know nothing about CAD or design.
I want to replace the hood mounted washer nozzles but every replacement I have tried, even the adjustable ones, fire far too low. I need a wedge shaped washer under the nozzle to aim it higher.
What tools can I use to design the needed washer?
Reactions: SvtLdr
I work with CAD everyday. Send me one of your low-shooting nozzles. I'll design you one with better aim.
