Any Ideas? GMRS mobile radio mounting locations
I mounted the box portion of my mtx275 to the steering column and copied Plumber1 and added an Ethernet Jack in one of the 12vt ports.
My ARR setup. I don’t think he’s still in business. It’s just a piece of rectangle with flanges on the end and mounts to existing holes in the roll bar. I have a retractable lanyard bought at a truck stop for trail use.
Reactions: LakeBeard
I have this also. I originally was going to fabricobble something similar out of UniStrut, but being as this was pre-made, it was cheaper. I now wish I'd actually gone ahead with the UniStrut idea - it would have been a lot nicer for cable wiring. But otherwise, the ARR mount is solid.
Same here. It’s a very simple design but I didn’t need to measure and figure out the bolt pattern. It installed in minutes’ it came with hardware and I just zip tied the cables. Plenty of room for my external speaker and room to add another radio.
He was a private guy who built these in his garage. Not sure if he still builds them but you can email him at rickhea@gmail.com and ask. The price was really reasonable when I got mine about 2 yrs ago.
Yeppers - I got mine about the same time - maybe a bit earlier. He once had a website, but last time I checked it was gone.
Reactions: Plumber1
Passenger airbag is removed . I personally do not care for airbags . Eventually I will most likely change out the steering wheel for a non-airbag steering wheel .
But what does your passenger think about the airbag?
Reactions: lBasket
