Engine swap well on it's way; pulled it this weekend. Oil pickup tube tells me everything I need to justify swapping the whole engine instead of just slapping a new head on this thing.
Where are you getting the new engine from?
Let us know how that engine works out for you. I’m contemplating whether I’m going to do my rebuild or if I’m going to buy a reman engine. I’ve heard horror stories from reman motors, but you never hear the good stories. I’m fixing to hit 200,000 miles and she’s running great but I’ll run her till she dies.
Hopefully you are not replacing the rear brake shoes. They are at best, maybe 1/3 used up. There is probably another 30,000 miles left on those.
Seriously? All the bits I could find on the internet said 8-12 mm new for those pads. That being the case I will toss the new shoes on the shelf for when they are needed and that makes the job I put off for a day a lot less hassle. Thanks!
fan resistor swap out, ironically nailed the replacement item w/same mfg codes as the oem. Time to get out for a proper test drive
edit added test drive photo
A little bath in the part washer/ aka the kitchen sink and the valve cover was ready for its coat of engine enamel. Won’t it be sad if my engine is all shiny and won’t run when I get done rebuilding it? Lol
How did you know this was going bad? Unlike the older ones, these seem harder to diagnose. Do they melt too?
Just so ya know that somebody is watching your progress, I've been watching your progress. It's a habit now to look out for updates. Keep up the good work. Hoping the best in results for your efforts.
Tim
Thanks Tim. First time rebuilding an engine so I’m just taking my time and making everything better than it started out. I’m just hoping it runs when I get it all back together lol I’ve slowly been getting this rust bucket to a decent solid Jeep.
Your saga has brought to mind the Harley guys building motors on the coffee table in the living room.
I’m ready for spring so I can get outside and get it all finished. Either that or I need to replace my glass coffee table with a sturdy wooden one lol
Started going after the AC clutch... wondering if the rebuilt alternator is making noise too. New one should be here Wednesday night.
