Right when I thought I was done with all the big maintenance stuff in my jeep…
A couple days ago, the temperature dropped down to around 0*F that night and for the first time I had problems with the heater. It had always worked previously, but now it was blowing cold air.
I knew that was a sign of possibly bad coolant, and I had never checked coolant on the tj since buying it. Sure enough, the coolant in the radiator was dark brown and had some particles in it.
I went to AutoZone to buy new coolant, planning to flush the whole system, and on the way home, I was almost home when the tj overheated on the highway just before my exit. Steam coming from under the hood. I pulled over, waited for it to cool down all the way for about 25 minutes, got into my neighborhood, it overheated again. From there, my Dad just came and towed me home with his jk.
I took apart all the pipes in the cooling system, flushed everything with the help of 3 YouTube videos. It was quite disgusting what came out of there.
After flushing it all, everything had gone really well, and I started putting it all back together. Got everything together except the thermostat housing. That thing is the biggest PITA to get back in since the serpentine belt is right there in the way of the lower bolt. I get it in, start putting coolant in, and it all starts leaking out of the thermostat housing… I think
I take the housing out, and it’s got a huge crack in it.
Back to AutoZone I go, get a new housing, and don’t have time to put it in yesterday.
After Christmas this morning, I go back out and put it in. Once again, huge PITA. I put the coolant in, and it is streaming out of somewhere. I assume it’s the thermostat housing, so I tighten it down as tight as I can. There is still a drip coming from there, but coolant seems to be streaming out of the oil pan gasket??
After some research, it seems that it could actually be leaking from the water pump and running down to there? Is that right? Do I need to replace water pump now?
Anyways, I’m feeling super defeated, not at all happy with this, but I am learning a lot. Is it worth me trying to fix it myself, or should I bring it in to a shop? I just don’t want to screw anything up any more than I have already. Id love to do it myself, but right now, I don’t know that’s a good idea.
If I do attempt to do it myself, Is there an easy way to get the serpentine belt off and back on so I can make sure the thermostat housing is on there correctly? Is the water pump what I need to replace? Am I missing something else?
I’m leaving tomorrow morning to go on vacation and will get back in a week. I’ve got some time to watch some videos and do some research. Obviously, I’d love to drive the tj soon after I get back, but if doing the work on it will take a couple days, I have my moms old car to drive. I mainly do not want to have to pay a shop to replace everything, however that might be best at this point.
I’m sorry that was so long, just kinda gotta rant about it
Thanks in advance to anyone can help!!
