You jeep people are so funny
OP needs to delete this thread or a mod needs to send this shit show to Off Topic. Because there is absolutely nothing techworthy that is going to be useful to anyone at this point.
let me try a reset:
tuned springs versus geometry correction brackets to improve ride quality
We aren't the only one who have had this happen. Pull back the rear carpet with a set of JKS pucks the have been around for a while. Jeep knew those bolts needed to be shorter than the surrounding bolts. JKS doesn't care, most owners don't pull back the carpet, most dismiss the small increase in vibration transition into the tub as a Jeep thing, and you have never paid attention.
Here are the factory body mounts. Two in the green box belong to the body mounts at the rear shock mount crossmember.
Jeep made these bolts shorter so that they don't punch into the tub. JKS didn't make these bolts short enough. Or maybe Jeep is trying to gaslight us and JKS body lifts don't punch holes in our tubs.
Look at my gaslighting. Look at it!
NOTICE: Use care when tightening bolts to avoid crushing factory rubber body mounts
This sure looks a lot more like installer error than a product issue to me.
There's a metal sleeve acting as a crush sleeve working with the bottom mounts that are also metal reinforced. The rubber is between the "washer" on either end and the frame's body mounts.
Do you really not know this?
JKS body mounts do not allow anyone to correctly torque the body mount bolts. Loctite has absolutely nothing to do with it. The polyurethane mounts compress and defeat the purpose of the isolater's internal sleeve. The bolts are never tight. Secured by loctite does not mean the bolt is tight.
Now we know that you don't understand how the factory isolaters work or how bolts work.
So what you're saying is that the bolts were punching into the metal and you didn't notice that there was any resistance there?
Let me guess- you hammered all the bolts down with an impact, huh?
Don't tell me you were using a torque wrench and torqued to 30-35 ft lbs, which are what the instructions CLEARLY state.
Here's the last 2 lines from the actual JKS body lift instructions regarding torquing the bolts:
"Using a torque wrench, tighten all 1/2” and 7/16” Bolts (B & D) to 30-35 ft-lbs.
NOTICE: Use care when tightening bolts to avoid crushing factory rubber body mounts."
Gotta follow the instructions bruh. Otherwise stuff happens and good parts get a bad rap. Perhaps that's why we've NEVER had an issue with these- in literally 2 decades... but you did.
Here's the url to the JKS body lifts: https://jksmfg.com/collections/wrangler-tj-lj-1997-2006/products/1-25-body-lift-wrangler-tj
You can see that the kits come with both longer and shorter bolts.
Now- I'm not saying that JKS couldn't have messed up the hardware on your kit. That wouldn't be the first time that a major off-road supplier got the wrong hardware in a package. That still doesn't give you the right to make the claim that all poly body lifts are bad because of your experience- especially when so many have used the same kit with no issues whatsoever.
Loc-tite definitely matters on bolts that aren't being tightened that much.
Disagree. There is being some tech talked about. The JKS body lift portions are real tech. I tried to torque my JKS Body lift to the required torque (35 ft-lbs, IIRC) and couldn't get there without WAY more squish than I was comfortable with. I could feel the bolt pulling the body in. So I ran them loose...until I noticed the bottom of the body lift flaring out. Then I pulled that garbage for some nice, solid aluminum lift pucks.
Here is the thing about plastic. It creeps...in that with constant force, it will almost flow, kinda like glass in a really old building will be thicker on the bottom than on the top. So...Dirk may NOT hear about issues with JKS body lifts. That doesn't mean JKS body lifts don't have issues though...just that he doesn't hear about it. It happens slowly, over time. It was two years or so before I really noticed my JKS pucks had deformed. In fact, I think I had a discussion with @jjvw about the same thing, when I first installed them and thought they would be good, cuz delrin is a pretty great material in the right application...turns out, body lift pucks are NOT the right application for Delrin.
I could go along with that if we didn't have so many local rigs running that body lift for so many years- our own included.
I will say that I always torqued them to feel though. No excessive "squish" and many years of service. I've not had a single one fail yet on any of these rigs around here.
Poly deforming is not necessarily poly failing. Poly coil spacers commonly take on the footprint of the of the coil. It's a SLIGHT indention where the 2 materials meet. That's expected when you sit a hard material like steel against poly. Gross deformation to the point of failure is another thing altogether.
I followed JKS's own instructions to reach whatever bolt torque they specify. Years later, after finding the pucks were loose from the body flopping around and since cracked spot welds, I asked the question of why. Then I switched a solid, non-compressible puck made of aluminum so I could actually tighten the bolts while also using bolts of the proper size. Look up what bolt lengths JKS provides. The 4 shorter ones are a 1/2" shorter than the 6 longer ones. You can clearly see that the factory bolts were about an inch shorter.
And again. I am not the only person to have figured this out. You sell this garbage. I presume you also install it. You can confirm this and send me $5000.
