Pretty sure I found the culprit. Decided to re torque EVERY bolt/nut that had to do with my suspension. Didn’t make it far without seeing things that were wrong. Rear upper control arm loose, and as you can see in this picture my axle side front lower control arm mount was centimeters away from unbolting. The washer beneath the nut doesn’t sit level with the mount so I can’t tighten it all the way because it just sits on I think the caster adjusting plate? Where should I go from here
