High idle after injectSor, spark plugs and coil swap (solved)
Jeep05tj
Geelong, Australia
Hey everyone, Firstly I have an 05 Tj 4.0, 6 speed manual.
Okay, long story slightly shorter...
About 2 months ago, I invested in a set of autolite xp985 iridium spark plugs, a blue streak coil rail and a set of 12 hole injectors from k suspension.
The jeep prior to the install of parts was running pretty normally but it had a slight flat spot I was trying to eliminate and a smooth idle never hurts.
After the the install of parts I reset the PCM (positive to ground trick, lights on and off) and started it up. The Jeep straight off the bat started to idle at 2000rpms and would climb to 2500 before going down to 1500. The hole tine it kept fluctuating. Just to be sure I did it right the first time, I reset the PCM again bit no difference.
Took it for a drive trying to get some time in, no difference.
Thinking it was possibly the injectors, I put the old factory ones in, no difference.
I did some research and people suggested the exhaust manifold gasket was causing a vacuum leak. I had a felpro one handy so I replaced that. Since I had the cats off, I changed the rms and oil pan gasket as they were leaking.
When I put it all back together, I used the 12 hole injectors and gave the intake manifold a thorough clean and checked for cracks.
Started it up and the idle is lower but sits at 1100rpms consistently now. It's also no longer fluctuating and not showing any cels.
I then changed back to the old standard ntk sparks and factory coil rail, no difference.
I read somewhere that you could cover the throttle body and attempt to suffocate the motor. If it continued to run, you have a vacuum leak, if it stalled, then it was likely an electrical/sensor issue.
I covered the throttle with a cap and the revs dripped to 800 and was idling pretty smooth. I started to take off the vacuum lines all over the intake to check for leaks. Everyone that came off would raise the revs.
Right now I'm at a loss, I have no idea what more I can do. I'm 95% it's vacuum related as I couldn't snuff the motor. Is there anywhere else I could check?
I've got a 3 day high country trek this Sunday and need to solve this issue asap!
Thanks all
Try plugging the vacuum port for the brake booster.
You need to plug ea vacuum port one at a time to test them, not just remove the hose and note an idle increase.
Yeah I gave that a go with carb cleaner. All around the intake manifold, throttle, vacuum lines and no change.
Alright I'll give the booster a go now
Reactions: AndyG
Solved!
JKP, I did what you said and started to plug the vacuum ports on the intake manifold.
I plugged the PCV port and it stalled. That was a great moment. That's when I realised that when i did the other sparks, coil etc that I changed the pcv value to one off rockauto. The opening in the value was larger on the new one which was obviously letting more air in and causing the high idle.
Thanks again guys
Reactions: AndyG and MichaelGH
Solved!
Thanks again guys
That's because the idiot parts lists are WRONG for the '05/'06. This keeps happening over and over and over and over again to just about everybody with an '05/'06 - including me, so you're in good company.
Yes, you should have a small orifice in the rear elbow and an open tube in the front one. If you need a new one for the rear, simply order the one for 04 and older, it fits and works.
Reactions: Zorba
