Opened my NX top today, I'm going to try and ignore the NASCAR style branding if I can
What is everyone doing for side/rear window storage when they're not in use?
Laid out flat under a bed.
If taking with, rolled up in the cloverpatch.
Not sure if they still make a tj one but JK should work.I was thinking for travel, in case of rain
I have the bestop window roll, it does a good job.
Does it have a gigantic, obnoxious logo?
OK Trektop people, what am I doing wrong with the J-hooks that are supposed to hook in the rear corners of the tub? I hooked them in the corners and they keep walking around and loosening the strap, what do I do to make them stay put?
Mine go pretty straight down (not to corners) and the buckle looks backwards. The loose strap is on the inside of the buckle.
If you haven't seen this video, about the 7:00 mark explains them.
If this helps anyone:
Just purchased and received a new bestop replace a top. It had the tramp stamp.
I can confirm that 30 min with VLR vinyl remover will remove 99% of the logo.
I’m confident after a few dusty trails and a couple trips to the pressure washer it will be 100% gone. Attached are the after photos… no before photo… if you’re reading this you’ve seen that monster.
Thanks
May give that a try as I bought my top just before the switch to the Jeep logo one.
Stuck with the massive tramp stamp.
