I agree, it would be great if you could just do the whole thing with a plain scanner. There really isn't any relearn process. The DRB sets the idle high, maybe 1200 rpm. At that point if you were out of sync it shows + or - to help you get it back in sync. Once you are close it reads degrees so you turn the OPDA until it reads zero or close to it. It's just a readout of what the timing difference is, there is no data stored in the PCM about it. Resetting the computer is obviously a total waste of time. You simply are setting it to zero, that's it.I'm not sure there is anything they could do to give us an easy way to launch it. But I don't like having to find or pay someone with a DRB to do it.
Surely recreating the drb3 functionality isn't beyond the capability of someone... I feel like a tuner manufacturer or @Wranglerfix could do it with some windows software and a pre existing USB to odb2 cable. Am I crazy?
You plug it in and follow the factory service manual, very complicated indeed.I don't know anyone on the forum that has or knows someone who has a DRBIII + knows how to use it properly.
Nobody reverse engineered anything, the DRB emulator is Chrysler software that is free.Someone already has it - but not sure how good the reverse engineering is.
I have the DRB3 and I've used torque and several other code readers. The DRB is pretty easy to navigate, you just have to remember to hit the "more" key. The tool is just expensive so not many people get to play with them. They can't enable/disable skim on their own, while they do write the firmware they don't generate it. Most people watch experienced mechanics use the DRB and don't really understand what's going so they give the tool a little more credit than it deserves. I hope that makes sense. Enabling and disabling SKIM is complicated and it does use the DRB but the DRB is just flashing the PCM which isn't complicated. I am positive that anybody on this forum could use it trouble free. I am not suggesting by a mile that I have some special skills because I bought a tool.
This part just really gets to me for some reason. Nobody is going to plug it in backwards, you imply that you need some special skills or something and this site to me is just the furthest thing from that. You don't have to be some smarty pants to do any of this stuff. Dealer mechanics can figure it out, so can most of the guys here. If you ever are in the area I'd be happy to let you use it.knows how to use it properly
Once they have the proper tool and code they will need to take that loose plug and connect it to the SKIM module and activate it first by placing your VIN in the module via their tool.
Once the SKIM module is recognized/activated they can place the key in the ignition, turn it on, (Not start) and enter the PIN code and hit "yes". If you have more than one key they just repeat the previous sentence. Now you are done.
I'd hope that when the dealer wouldn't take your money it would tell you what level of simple it is. Did you tell them you read on the internet that it's easy? (just kidding) I have heard it is easier to enable versus disable to prevent just disabling skim with a scan tool. Let me know if you find out any details. I don't know all about it and certainly enjoy learning what can and can't be done. You do need the code from the dealer to work with the skim module at some point. I have three good keys so I've never had to dive into it but I did get the code just in case the dealership database is encrypted and they don't want to pay the bitcoin ransom.I stopped in to my local dealer today and they didn't seem interested in doing this.
You don't need a DRB3, their computer system has the emulator and unless you need to re-flash the PCM that's not an issue. If the process is "easy" like you say the emulator on their current system will work fine. This is probably a case of a less than super smart service manager.Their issue is that the service writer didn't believe they had a drb3.
I'm chasing down a lead with a local ecm guy that's up for trying it out. He commented that people usually want to go the other way so that leads me to believe he's at least been into those functions with it.
There is when I plug my DRB III into my 05 LJ Rubicon:There really isn't any relearn process.
I know this might be a big ask, but if you know how, could you take screenshots like that of the steps required to enable a SKIM and program a key? That could help a lot of us that can find someone with the tool but without the experience.There is when I plug my DRB III into my 05 LJ Rubicon:
I can't figure out what it does, though. The engine has to be off to do it, and not much happens, other than you get a message that it's done after a few seconds...
Perhaps it just sets a flag used by the PCM to do something the next time it's running?
I just got this DRB III, so I’m as far away from a subject matter expert as one can get, unfortunately. However, I’ll look through the menus and take some screen shots if that will help.I know this might be a big ask, but if you know how, could you take screenshots like that of the steps required to enable a SKIM and program a key? That could help a lot of us that can find someone with the tool but without the experience.
