I'd love to hear @starkey480's input. I think he's still running 35s on a super 35 and last I read was keeping up with buggies out in Arizona.
Here are the numbers I've found. Someone show me cheaper if you know. Remember, my main goal is cost effective solution for 33s. I'm not going to 35s. Based on what I've read I also like the idea of leaving the rear open for now to save money to do the rear like I want. However, I want to change to 456 gears which means I need new carriers. I don't want to buy an open carrier set only to take it out six months later for a trutrac and have to pay to get the axle setup again. I'm definitely in a pickle.I could be mistaken here, but I believe the expensive part of the super 35 kit is the carrier replacement, and that gets taken care of by whichever locker you decide to go with. At the end of the day the cost difference between building the 35 and switching to a 44 is the cost of the 1541 axle shafts ~ $300, vs the cost of a complete 44 axle assembly $?. You're going to pay for a locker and gearing regardless of which housing you use. The super 35 should be plenty strong, plus lighter and better ground clearance.
Since a significant portion of the cost is in the install, I'd figure out exactly how you want it done and do it all at once, even if that means saving for a few more months. Those prices seem about right, maybe a little high on the super 35 kit - I'm seeing the axle shafts for $300, and the Truetrac for $500. Assuming there might be some additional bearings etc. that need to be purchased though.Here are the numbers I've found. Someone show me cheaper if you know. Remember, my main goal is cost effective solution for 33s. I'm not going to 35s. Based on what I've read I also like the idea of leaving the rear open for now to save money to do the rear like I want. However, I want to change to 456 gears which means I need new carriers. I don't want to buy an open carrier set only to take it out six months later for a trutrac and have to pay to get the axle setup again. I'm definitely in a pickle.
Keep my 35c
$1200- Super 35 kit (includes trutrac carrier and bearings and 1541 shafts)
$150-$200 for R&P
$500 for shop fees
Dana 44 swap
$1200ish for the axle that may or may not come with gears or locker I need
$400 for locker if not included
$150-200 for R&P
$500 for shop fees
I don't see the pickle here. You are not broken. Your rig runs and drives OK at the moment. You can likely do all of your current offroad plans as it sits. Take some time, save up the money to do it right the first time. Do your gears and lockers / LSD, rear axle solution at the same time. This will save you money and get you what you want. Why such a hurry?Here are the numbers I've found. Someone show me cheaper if you know. Remember, my main goal is cost effective solution for 33s. I'm not going to 35s. Based on what I've read I also like the idea of leaving the rear open for now to save money to do the rear like I want. However, I want to change to 456 gears which means I need new carriers. I don't want to buy an open carrier set only to take it out six months later for a trutrac and have to pay to get the axle setup again. I'm definitely in a pickle.
Keep my 35c
$150-$200 for R&P
$500 for shop fees
Dana 44 swap
$150-200 for R&P
$500 for shop fees
What I'm seeing is the kits usually have ARB, OX, and Detroit (clutch type) available in 30 spline. You can also buy a trutrac in 30 spline separately. But if you get the parts and add all the bearings it ends up close to 1200 which is where I got that number. Rusty's has a kit with Detroit, Ten axles, and bearings for around 1000.Since a significant portion of the cost is in the install, I'd figure out exactly how you want it done and do it all at once, even if that means saving for a few more months. Those prices seem about right, maybe a little high on the super 35 kit - I'm seeing the axle shafts for $300, and the Truetrac for $500. Assuming there might be some additional bearings etc. that need to be purchased though.
Your total cost for the 35 and the 44 might end up being similar, but I believe I've read the super 35 shafts are stronger than the factory 44 shafts. You'd only be adding more weight and losing clearance by going to the larger axle. Limited to 35 inch tires with both setups, so I don't personally see much benefit to a 44.
The gears are what's bothering me. With 3.07 in it right now I have no power, no 5th gear, and it's hard to drive to trails on the highway. Once I'm on the trails it's fine.I don't see the pickle here. You are not broken. Your rig runs and drives OK at the moment. You can likely do all of your current offroad plans as it sits. Take some time, save up the money to do it right the first time. Do your gears and lockers / LSD, rear axle solution at the same time. This will save you money and get you what you want. Why such a hurry?
Jeff
Who has a Super 35 kit with a Truetrac? That's not a common option for a Super 35 since a Truetrac (a limited slip differential) doesn't put nearly as much stress on the axle shafts as a locker like a Detroit Locker does.Here are the numbers I've found. Someone show me cheaper if you know. Remember, my main goal is cost effective solution for 33s. I'm not going to 35s. Based on what I've read I also like the idea of leaving the rear open for now to save money to do the rear like I want. However, I want to change to 456 gears which means I need new carriers. I don't want to buy an open carrier set only to take it out six months later for a trutrac and have to pay to get the axle setup again. I'm definitely in a pickle.
Keep my 35c
Somebody's got something wrong there for sure. Pretty sure 30 spline Dana 35 TrueTracs were available briefly way back when the super 35 was born, but they have been long gone for a while now, if they were ever even real. I can't confirm they were.Who has a Super 35 kit with a Truetrac? That's not a common option for a Super 35 since a Truetrac (a limited slip differential) doesn't put nearly as much stress on the axle shafts as a locker like a Detroit Locker does.
I was looking at the 44, apologies. The kits I was looking at have either the Yukon grizzly or the Detroit noslip which are both clutch type, not torsion.Who has a Super 35 kit with a Truetrac? That's not a common option for a Super 35 since a Truetrac (a limited slip differential) doesn't put nearly as much stress on the axle shafts as a locker like a Detroit Locker does.
There is no such thing as a Detroit noslip: https://www.eaton.com/us/en-us/prod...action-control/aftermarket-differentials.html . There is a Detroit no-spin which is basically a Detroit Locker without the case and it is only made for heavy duty applications: https://www.eaton.com/content/dam/e...rol/nospin/eaton-nospin-application-guide.pdf .I was looking at the 44, apologies. The kits I was looking at have either the Yukon grizzly or the Detroit noslip which are both clutch type, not torsion.
The Rusty's kit is an elocker, not a no spin. Thanks for the correction.There is no such thing as a Detroit noslip: https://www.eaton.com/us/en-us/prod...action-control/aftermarket-differentials.html . There is a Detroit no-spin which is basically a Detroit Locker without the case and it is only made for heavy duty applications: https://www.eaton.com/content/dam/e...rol/nospin/eaton-nospin-application-guide.pdf .
I wouldn't buy anything from Rusty's. Rusty has earned a bad reputation that started many years ago for not taking care of his customers after the sale.The Rusty's kit is an elocker, not a no spin. Thanks for the correction.
Their kit is confirmed to not be 1541 axles, which explains the cost with an e locker. I would probably buy the parts individually.I wouldn't buy anything from Rusty's. Rusty has earned a bad reputation that started many years ago for not taking care of his customers after the sale.
I didn't create the below meme that shows the general feelings about him and his products.
If any Super 35 kit you find comes with anything but 1541H axle shafts steer clear of it. 1541H shafts are the only type of shafts that will hold up in a Dana 35.Their kit is confirmed to not be 1541 axles, which explains the cost with an e locker. I would probably buy the parts individually.
What would be "super" about it without the 1541 shafts?If any Super 35 kit comes with anything but 1541H axle shafts steer clear of it.
You didn't mention what tire size you plan on running, I'm still curious there...Because I can, seriously I just want to and besides I already have the D44HPHD Differential also have an old dana 50 out of a ford excursion and the 14 bolt FF out of an old Suburban. You can shoehorn a Dana 50 R&P into a Dana 44 and run D/60 GM Kingpin Set up and lose zero Ground Clearance and you only give up 1/2 of an inch +/- in Ground Clearance going to an 8.8 vs the Dana 44 for the Rear and who would not want a full floater Rear 1/2 thick DOM Axle tubes Front and Rear larger Diameter Axles, Larger R&P Front and Rear less unsprung weight vs 14 bolt Dana 60 set up less loss of ground clearance vs 14bolt Dana 60 setup bigger u joints and stock off the shelf GM Brakes and bearings for the Hubs front and back and Disc Brakes on all four corners and a wider WMS to WMS for Bigger Tires and who doesn't love bigger tires.
Bigger Brakes
Bigger Axles
Bigger R&P
Thicker Axle Tubes
Bigger U Joints
Less Weight
Less Loss of Ground Clearance
Full Floater Rear
Parts Availability Brakes Bearings Ect
Wider WMS better tire clearance / less rubbing during turns
No more Unit Bearings / Manual Lockout Hubs Are Serviceable
Plenty of Aftermarket Support for the 14 Bolt, D/60, Ford 8.8, D50
And I have a Mill, a Lathe and Welder, and like building and improving stuff
