I will be building-up a Dana 30 high pinion from a 98 XJ (no CAD) for my LJ and am requesting build advice.
I currently have a 3" lift with 33" tires and will be installing 4.88 gears. There is a small chance of 35" tires and 5.13 gearing in the future.
Questions:
Questions:
- Should I truss my axle - forum sentiment seems to be 'no', but would like to hear opinions on this?
- Should I reinforce the inner Cs?
- Does a heavy duty differential cover help with the rigidity of the center housing?
- Which brand of unit bearings should I purchase?
- I will be purchasing chromoly axles. Should I go 30 spline or 27 spline? Which u-joints should I run?
- I will be installing an ARB air locker that I have not yet purchased (could be 27 spline or 30 spline)?
