Aftermarket subwoofer replacement for factory subwoofer?
Every video and picture I see of the factory sub shows two terminals (one on each side) with a total of four wires being used (two for each coil).
Never thought to check a video or picture. Mine has two wires from the amp circuit board that connect to my single voice coil sub but it's been awhile since I actually installed it. I've replaced the speaker twice and the first time I was actually concerned about how I was going to do it until I saw how the amp was wired. I don't have any good pictures of the board to post but I don't remember it being difficult to see that you weren't connecting half the amp.
The factory amp only has two wires and not four, you can run a single voice coil sub with no modifications.
Edit: for what it's worth I don't think dual voice coil subs should be run on two channels, they will fight each other, the dual configurations is just to allow you to run the speaker series or parallel to give you different impeadence options but whatever floats your boat
A DVC sub can take two amplified channels, and a DVC is designed as such so you can easily wire it to a wide array of amps, watts/channels/impedence.
As an example, take the common center console replacement sub, the Kicker 6.75" with 2 Ohm DVC, 150 watts and 300 watts peak.
You could have 1 or 2 channels from an amplifier power the Kicker. The Kicker could be wired from an amplifier that has at least:
1) 1 channel with 1 Ohm, 300 watts peak, 150 RMS. Parallel.
2) 1 channel with 4 Ohm, 300 watts peak, 150 RMS. Series.
3) 2 channels, each with 2 Ohm, 150 watts peak and 75 watts RMS. Direct to each VC.
I have a 6 channel amplifier with two channels going to the DVC sub, as long as you use the correct power, multiple amp channels will drive a DVC sub.
"Most" speaker and amp manufacturers don't recommend this configuration, it generates unnecessary heat in the voice coil due to small differences in the amp output stages. At high powers the loss can be large. You can't perfectly balance them and any differences in current flow generates heat and doesn't contribute to movement. This isn't a problem when they are wired in series or parallel on the same channel or a bridged channel. At the end of the day It's your system so wire it however you want.
I have never ever seen or read any quality brand, audio shop or audiophile recommend against it.
I actually have a quad coil sub woofer that I use four amplified channels on, comes recommended to do that.
Good to know, you have more experience with this stuff than I do that's for sure.
I'd agree with this because I've never seen a wiring diagram with 2 channels, 1 for each voice coil. The most common configuration with 2 channels is 2 channels bridged, then wired to the sub with the voicecoils in series or parallel. There may be exceptions to this but I am not familiar with them.
So because you have never seen it means the most common method is what you have seen? Here is a picture so you can can visualize.
As a reminder, never assume your amplifier is bridgeable – always check!
Another source as well, not coming from a random forum member.
We’ll be clear: A single voice coil subwoofer isn’t “better” than a dual voice coil sub, or vice versa. The only benefit of a DVC sub is that the coils can be wired in series, in parallel, or each can be fed directly to an amplifier channel. There are benefits in terms of installation flexibility, but the number of connections to the voice coil doesn’t improve the driver’s performance or sound quality.
https://www.bestcaraudio.com/subwoofers-and-amplifiers-lets-talk-about-ohms-and-loads/
Rockford, kicker, JL, alpine, and stereo integrity are the sub brands I’m most familiar with. I’ve never seen them recommend multiple channels for multiple voicecoils but I’m open to being proven wrong. I’m certainly not familiar with *all* brands or bestcaraudio.com or soundcertified.com. It’s not a wiring configuration I’ve seen recommended.
I’m not interested in getting into an argument. I’m just saying it’s not something I’ve seen before. I’m curious which amp and/or sub manufacturers recommend that configuration.
The reason wiring each voice coil independently is not as commonly seen as Series/Parallel wiring is generally a subwoofer or multiple subwoofers, when used in car audio, is/are powered by a mono-amp. A mono-amp has only one channel so Series or Parallel wiring must be used, and a DVC sub gives you a wider range of amplifiers to choose from.
This is from JL audio, while they don't have a fancy picture it is written in their literature:
How are dual voice coil speakers rated for power handling?
A dual voice coil speaker’s power handling is typically specified by manufacturers for the whole speaker. This means that a 250 Watt dual voice coil driver is designed to handle a total of 250 Watts, regardless of whether the coils are wired independently, in series or in parallel
https://jlaudio.zendesk.com/hc/en-us/articles/204374150-Speaker-Wiring-Tutorial
A Dual VC Sub installed 15-yrs ago in my cargo van and still rocking.. And that’s an old RF G series Punch 800 4ch amp that has real horse power. The sub is still kicking ass wired with two channels off the amp.
First off, if you're going to go through the effort of replacing the factory subwoofer, don't use the factory amp. It's absolute garbage, and even with an aftermarket sub like a Kicker, the factory amp simply can't power an aftermarket sub to sound anywhere near as good as it should.
I recently upgraded the audio (including the factory subwoofer and amp) in my 2005 Rubicon, and this is what I used:
https://www.amazon.com/dp/B00UG7AWH8/?tag=wranglerorg-20
https://www.amazon.com/gp/product/B01BLVEZG6/?tag=wranglerorg-20
That amp is TINY, and it's waterproof as well. It has more than enough power to power that subwoofer, which also happens to fit in the factory subwoofer enclosure with very minimal modifications (you just have to Dremel some of the inner pieces of the factory enclosure in order for the new subwoofer to fit, since it's a little deeper than the stock one).
Anyways, it was super easy to install, and I can't tell you how huge of an improvement it is over stock. Seriously, words can't even describe it. The end result is a subwoofer that totally transforms the audio in the vehicle. I don't listen to bass heavy music (i.e. rap), mostly just blues, jazz, rock, and some twangy country. However, this thing just totally brings the music to life, even with the subwoofer only on half volume (any more than that and it was really starting to rattle things).
You honestly can't even compare the factory subwoofer (or that crappy Quadratec one) to this setup. This is mainly to do with the fact that the factory amp (and the wiring used) is just a complete piece of crap.
It doesn't matter what subwoofer you put in there to replace the stock one, no subwoofer you use is going to sound that great, and it's entirely because of the factory amp. It simply will not power a decent aftermarket sub (or even the stock sub) the way you or I want it to.
Can this be done without replacing the factory head unit? I want to keep the clean aesthetic of the original head unit but just replace the subwoofer and amp, if it's possible.
Yes, depends on the amp, gut generally speaking just add an LOC to your shopping list. Example is
https://www.crutchfield.com/p_161LC2IB/AudioControl-LC2i-Line-Output-Converter-Black.html
Bunch of forum threads on this topic if you search around.
One brand sells plug n play gear, but very expensive. Here is a picture of the amp connected to the stock HU.
