I have a 2000 jeep wrangler with a 4 inch lift and 33 inch tires ive been fight with this issue for a little while now and thought I had fixed it but it came back. When I go close to full lock or at full lock with my steering wheel while backing up (in 2wd) the front wheels start binding and hopping. I thought I had fixed it when I found that the front track bar the previous owner put in was loose cause they didn't use the proper bolt causing it to stretch. I put a new/ larger bolt in and it seemed to help it for a while until a few weeks ago when it started doing it again pretty badly is it my alignment? Is it the bolt in the track bar again? Is it a worn out tie rod? Is it my steering box? Or is there something going on in my differential? Please help!!
