Wheel Speed Sensor Cable to Front Control Arm Clips
TJRD4
NC
Anyone know where one can find these type of push in cable mounts for the wheel speed sensor to control arm holes?
There are tons of options on amazon but they mostly only work for 1/4" holes. The control arm holes are about 3/8" or about 9.5mm.
The orignal jeep/mopar part number is 5212 8162 but obviously discontinued... In years past (long time ago) I remember the new wheel speed sensor coming with these already but the new ones at rockauto and others do not. You need two per side on the front; none are needed on the rear since they fit in brackets.
Thanks!
Thanks. Same concept agreed; the challenge with those and others ive found on amazon is the tree part diameter is too small.
With the mounting hole on the control arm being 3/8" id think you need it to be at least a 1/16th larger.
One thing I've done in the past to secure something is use a large enough cable tie that the head won't fit through the hole.
Push the cable tie through from the back of the hole, round the cable, then back through the hole and fasten the cable tie.
It can be awkward threading the tie through and getting it tight but it does the job.
Reactions: TJRD4
That’s a great idea and it’ll look clean. Thank you!
