Wheel bearings
Couple of questions. 4.0L, 3 sp. 98 TJ Dana 30/Dana 35. 2.5 lift on 33's: I'm hearing "coffee can full of gravel" sounds from front right wheel. I assume it is the bearings??? Just got 33's this month. Maybe they exacerbated the problem.
1) I'm good with tools and have quite a few, but never worked on cars a lot (as I see most here do). Is this a pretty straight forward task for a noob to learn, or take it to the shop?
2) If it is a DIY, I see the link above is for D44s. Can someone direct me to the Dana 30/35 sets?
Pretty straightforward. You will need a 36mm socket for the stub nut. They can be a pita so start soaking them with Kroil a few days prior to the job.
