What is wrong with all my thermostats?
I wouldn't swap it if it's working.
Flowkooler/Robertshaw is supposed to me more stable, but I really can't tell if it's any more stable than a Stant Superstat based on the TJ gauge. You'd have to compare OBDII data since the gauge is somewhat damped.
Advance swapped out my failed Stant Superstat with a Motorad Ultrastat. Doesn't look bad, but doesn't have the jiggle vent.
Reactions: Moglocker
I redid the whole system mopar everything in 2020,been all over the USA ,no problems,if I sit idling in the summer w/ac it will climb passed half way,I think I might do something to raise the rpm to keep the (wench)lol cool when I go into a store or something.
Pick up a bluetooth OBD reader to see what your temps actually are.
Mine will approach 220 if it's scorching out, idling with the AC in GA. The gauge just shows a needle width or so above 210. As soon as I start driving, it's 205 to 210. Mopar rad, Robertshaw thermostat, Advance pump.
And the current 05, 06 TJ MOPAR cam sensor is junk as well, it is not the same as the original one.
Not sure what you mean by current 05-06 TJ Mopar cam sensor…it’s been discontinued for years.
