Tworley build
I came into possession of a York 210 with some other bits and pieces.
Can anyone tell me what these pieces are?
  • Wow
Reactions: lBasket
Actually, quick research pulls up this really simple bracket :unsure:
If the York works it's nearly 70% cheaper to just buy the bracket, idler and belt.
The good bracket, idler and belt are still a small portion of the costs. Building a York system is an extensive nickel and dime project to make work well. It's the same as highlines. The fenders are not the expensive part.
IIRC, the Sanden setup was over $300. I paid $50 for the compressor, the rest was fittings/hoses
Reactions: Wildman
I don't really feel like I nickel and dimed anything with my high line and can't point to any issues specific to that project. For the York you could argue some fittings and lines, perhaps, but if you're doing the same set up with a different air system you're in the same ballpark.
On the daily driver--i was on a work trip on Tuesday and I began to hear a metallic scraping sound that got progressively worse.
Ran to NAPA today and got brakes knowing that was the issue.
These have 153k miles on them. Fronts I replaced at 106k.
I always changed mine at 50k for my F150. You must drive better.
What the heck wiped one pad like that? Sliders are ok?
Reactions: FarFire70
